typhoon or gt40?
heh, so we meet again...
if i were you (imo) i would stay away from proffesional products. think about it... you drive an american musce car, and i take it you're against imports right?
wether you are or not isn't the point, the point is... prof. prod. is a knockoff brand made in ***in china, and you're car is made in america.... see how that doesn't work... im not dissin on the typhoon or anything, but the thing is... well... its made in china man...cmon
as far as comparing... i LOVE my gt40 intake... it came with the car, but still... i love it, anyways if you think that the gt-4o intake isn't worth the moola, than wy not try that new bbk ssi intake, i've heard nothing but great things about it... and it comes with fuel rails too!...sweet!
edelbrock rpm
Not a big fan of Knock off products either.
I don't know if PP makes a knock off of the rpm like they do of the performer.
Gt40 is a very good all around intake, makes more average hp and torgue then most others. But as you said it is costly.
I went ahead and threw down the dough to get a GT-40 n threw on a 1" spacer with it, and @ the same time a 70mm tb and egr spacer...now i havent yet down cams or heads, and in that case some people say they wouldnt notice a difference, once i got it all together and took it out a noticed a very reasonable difference and couldnt get enough of it, and this is with multiple codes being pulled and a nasty idle problem...so i say go for it, nobody knows your car better than ford anyway, and you pay for what you get
Actually, the Typhoon is a knock off of the Edelbrock Performer RPM. I have one actually, and it seems as though they're hit or miss with their quality. I was fortunate with mine being pretty good, although the injector bosses leave a little to be desired, since I'll have to remove some casting flash from them.
i have the typhoon, there's no dip in the thermostat housing to allow you to adjust the distributor easily, the inside should be cleaned up and it doesn't come with an oil shield for the lower intake, so oil pushes it's way up the pcv into the upper intake. But if you can use a shield off the stock one...(not sure you can) and are good at finding tdc with dist out(so you can adjust with less room)... and want to port or polish it anyway, it is a good intake. it definately outperforms the gt-40/cobra up high, and about matches it down low, so if the price is right, which it was for me, go for it,but if you want to spend a little more, to save a lot of hassle, go with the performer or rpm from edelbrock, they are much better quality, even though they give about the same performance.
Typhoon will not "leak" under boost or NOS...yes the intake is made in china..Ford racing has followed suit with it's cobra intake..and I would not be surprised if the GT40 followed suit. I like the Typhoon, it serves my engine well in both looks and performance (matching that of my RPM..no difference). GT40 is one hell of a good intake, tests show it carrying it's weight well against the biggest and newest compeditors. For my case the Typhoon served my needs for what my car is..some show/good go, but if just for the GO factor I think the GT40 would make better power down low and just as much through the mid and upper...I like it and would recomend that one for you.
I'm wondering why you're asking this damn question. You don't need either of hose. You've asked before a couple times and you've got good answers. Get a TFS R or an RPM II if you're gonna do the 347. If you're staying 306 get a Track Heat.
