typhoon+thumper+bcam = decent??
  • Thread starter Thread starter Foxfan88
  • Start date Start date Nov 14, 2005
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Nov 14, 2005
  • Nov 14, 2005
think that HCI combo is a good match??
E
emagdnim
391
15
28
Nov 14, 2005
  • Nov 14, 2005
typhoon is overkill for thumper heads your better off with a tmoss ported lower and stock.
Paul Perreca
1,085
  • Nov 14, 2005
maybe cobra intake
vikingpower
656
CWU Ellensburg, WA
Nov 14, 2005
  • Nov 14, 2005
Anythings better than the stock intake. I used a Typhoon on my stock long block and it opened up the top-end breathing significantly. This month in HOT ROD they did a 5.0 buildup and a RPM II was worth about 20hp over the H.O. intake with (stock) E7 heads, so the Typhoon will be worth about the same HP. And dont waste your time with the B cam its WAAAAAAYYYY outdated!
E
emagdnim
391
15
28
Nov 14, 2005
  • Nov 14, 2005
Theres been dyno proven results where a stock ported lower makes more overall power then a cobra intake on ported e7s.. The cobra has a bit higher peak hp number in the upper rpms but the powerband is fatter with a tmoss ported lower.
8950HO
658
  • Nov 14, 2005
Forget the B cam,theres better choices out there.
dstanggt50
1,316
Woodinville, WA
Nov 14, 2005
  • Nov 14, 2005
Cobra intakes are pretty cheap, especially if you look for a used one. It will be considerably better than stock, and will match other combos better over the ported stocker if you ever upgrade from ported e7's.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Nov 14, 2005
  • Nov 14, 2005
well the b cam is set in stone. i already built the shortblock and its in there so.....
Scorcher2005
883
South Carolina
Nov 14, 2005
  • Nov 14, 2005
nice time to ask the question...
maverick0716
3,924
Chilliwack, BC, Canada
Nov 15, 2005
#10
  • Nov 15, 2005
  • #10
Sure there are better cams out there....but you can still make a lot of power with a B303.
18mustangs
533
Virginia Beach, VA
Nov 15, 2005
#11
  • Nov 15, 2005
  • #11
The B cam is a good little cam and I really like mine. That being said as soon as I can I'm getting a TFS stage 1 as it makes more power, has better driveability, and gets better gas mileage than the B303 (I've witnessed this on my brother's car). If the motor isn't in the car yet I'd recommend looking at the TFS cams, but you'll like the B cam. I personally like the Edelbrock over the Typhoon as the workmanship that I've seen on a friend's Typhoon looked a bit rough. If you go with the GT40\Explorer\Early non-chinese Cobra or the Edelbrock I think you'll be happy.
Tim
Daniel50
716
Discovery Bay, CA
Nov 15, 2005
#12
  • Nov 15, 2005
  • #12
why would you build something and than ask the question on the best combo?
8950HO
658
#13
  • Nov 15, 2005
  • #13
Hmmm,..
I
IntenseBlue
946
#14
  • Nov 15, 2005
  • #14
Get a TFS Street Heat intake.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Nov 15, 2005
#15
  • Nov 15, 2005
  • #15
well my real question lies with the intake now, i have the Bcam and thats what i will use. I am getting thumpers so i was wanting to know whats the best intake to get.
Daniel50
716
Discovery Bay, CA
Nov 15, 2005
#16
  • Nov 15, 2005
  • #16
so you have a ford b cam. ford e7's that are ported, why not go with a ford racing cobra manifold? or a tmoss ported lower? you can get the cobra manifold used for around 250 or the tmoss for 130.
Advice after break down.
  • bjornsn95
  • Jan 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
  • Sticky
Free Beta Access: Tool I Built to Hunt Fox Bodies Faster
  • MRaburn
  • Mar 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 7, 2026
FastDriver
R
Fox Foxbody Notchback Coupe 1979
  • robrouck
  • Apr 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 20, 2026
slow84lx
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
