SN95 U/d Pulleys And Amp Issues?
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,311
374
134
Between the Red and Rio
Hey guys w 94/5 gt's w under drive pulleys did y'all experience an amp loss w them- dim lights etc? My 90 came w em and I had to add a higher amp alternator to compensate. With the stock 130 amp on the sn's is there an issue?
Mustang5L5
Mod Dude
Feb 18, 2001
39,971
15,696
224
Massachusetts
You don't need a higher amp alternator. At best, you are probably using maybe 100A tops at full load.
The issue is pulley RPM. The alternator does have a minimum RpM required to output 12v. The underdrives have slowed the accessories down. You need to spin the alt slightly faster to compensate.
Stock Sn95 pulley is about 2.75". ASP makes ford alt pulleys in 1 7/8", 2", and 2.5" diameters for about $20. You can also use a 2" fox mustang alt pulley. Keep in mind with these pulleys you may need a 5/8" ID washer as a spacer to keep the pulley from hitting the alt case.
90lxwhite
5 Year Member
Aug 25, 2011
3,311
374
134
Thanks. Prob won't do pulleys on the 95 but was just curious. I don't think they're worth messing with.
revhead347
Apparently my ex-husband made that mistake.
9,133
1,675
214
Acworth, GA
If your alternator is not producing good voltage at idle with under drive pulleys, I've found the fix. Put big heads and a giant ass cam on a stroker engine that has to idle at 1000 rpms anyway, and it all sorts itself out.
Kurt
