U-Joint Leaking?
  • Thread starter Thread starter savegoodautonfg
  • Start date Start date Sep 15, 2006
  • 3
First Prev 3 of 3
HISSIN50
34
129
Sep 20, 2006
#41
  • Sep 20, 2006
  • #41
This is hilarious!
JChalfan
551
Bellevue, WA
Sep 20, 2006
#42
  • Sep 20, 2006
  • #42
Wow, that was impressive, and at 2 in the morning none the less!
And to think it's gone this far without anyone saying "unobtainium". Incredible.
Jeff
mustang6tee8
375
College Station, TX
Sep 20, 2006
#43
  • Sep 20, 2006
  • #43
Uhh, well, 4am works too!
savegoodautonfg
1,085
#44
  • Sep 20, 2006
  • #44
It's so funny how good this guy SVT lies. i mean i knew it was'nt true but still he makes up some funny sh it
QUIKSVT
93
#45
  • Sep 20, 2006
  • #45
mustang6tee8 said:
No, sorry Fett, CNP leaves a residual sludge after too much use, I've heard from the top-fuel dragster crowd that an entire gallon of C.L.R. works even better than CNP, because it reduces the fuel temperature by 45 degrees, gives you 88hp, AND is so reactive, that once the exhaust fumes exit the engine into the exhaust system, it mixes with the Nitrogen in the air and leaves a byproduct of chromic anhydride (the basis of hexavalent chrome plating) nitride on the inside of the exhaust piping, leaving a clean, shiny tailpipe, every time you start the car.
QUIKSVT- I hear you also have the prototype Adamantium injected polychromolycarbonite camshaft made by Cams-on-Crack Racing, how did that turn out for you?? I was glad when I heard you got the lobes coated with carbonite- good choice!
savegoodautonfg- If you're looking for a little (or, a LOT) more traction (this also from top-fuel dragsters that run low 4 second quarter miles) I suggest you add half a gallon, maybe even 3 quarts of Detramol or Genalite IIIR traction fluids (or even a 3:1 combination for the track) in each rear tire. This was just released on the market not even 3 weeks ago. It's a semi-fluid, with an astounding consistency of a (no joke) McDonald's milkshake. When you accelerate, even slowly, the centrifugal forces bring the traction fluid to the circumference of the tire, stirs up the microfibers and electrons, which creates the desired addition of rotational electro-kinetic force. The weight of the fluid creates a higher rate of torque on the tire pressing down on the pavement, resulting in exponentially increasing acceleration, derived from 34psi of 977 forced induction horsepower. However its best chemical properties is the way it softens up the tread of the tire, from the inside, and lets it dig into the small crevaces of the concrete. QUICKSVT had to stop using it, because the engine made his pushrods and lifters look like the 4th of July, and I believe blended the Titanium and Digestium coated internals of his Viper-spec T56 into a bowl of rare-earth metal flavored oatmeal.
I surrender. You just gave me a headache from reading that.
savegoodautonfg
1,085
#46
  • Sep 20, 2006
  • #46
QUIKSVT you are a really good liar.
mustang6tee8
375
College Station, TX
Sep 20, 2006
#47
  • Sep 20, 2006
  • #47
are you talking about QUIKSVT, or me (mustang6tee8)? i'm the one who wrote the really long post at 3:53am.
QUIKSVT
93
#48
  • Sep 21, 2006
  • #48
That brings up another question of credibility... Are you on crack?
JChalfan
551
Bellevue, WA
Sep 21, 2006
#49
  • Sep 21, 2006
  • #49
That was a pretty lucid post for 4am. Either you wake up really early, or QUIKSVT's on to something...
Jeff
HISSIN50
34
129
Sep 22, 2006
#50
  • Sep 22, 2006
  • #50
I think there's only a couple of us on the thread who arent hopped-up on something. The others are hilarious, delusional, or both.
mustang6tee8
375
College Station, TX
Sep 27, 2006
#51
  • Sep 27, 2006
  • #51
Hey man, I'm clean! I'd like to think I'm hilarious, and I'm sure on the slightly delusional part.
  • 3
First Prev 3 of 3
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
