uh ohhh!!!!!
  • Thread starter Thread starter 873Stang
  • Start date Start date Mar 20, 2007
873Stang
221
riverside
Mar 20, 2007
  • Mar 20, 2007
i think i broke something but i dont know what! but when i go WOT i can hear a very loud chattering and it only happens when flooring or WOT. any ideas of where to start its metal hitting metal but in a chattering sound.
also i but in a ford racing clutch quad and my pedal is lose if you tap it it (not enguaging it) just tapping it, is this normal???
:SNSign:
webslinger67
64
  • Mar 20, 2007
where is the noise coming from?
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Mar 20, 2007
  • Mar 20, 2007
your most likely hearing detonation - switch to a higher octane gas and see if it goes away. If yoiu run an engine in detonation long enough, yoiu WILL break something.
JChalfan
551
Bellevue, WA
Mar 20, 2007
  • Mar 20, 2007
That's definitely possible.
Have you checked the timing to see where it's set at? Don't forget to remove the spout connector first.
tbovee
129
Fredericksburg Va
Mar 20, 2007
  • Mar 20, 2007
I agree, check timing and fuel grade.
Black1987Stang
1,422
Jersey Shore
Mar 20, 2007
  • Mar 20, 2007
Check the above things, some more detailed description would help alot. If it sounds like theres a midget under your lower intake with a hammer under WOT it's most likely your lifters going out....thats what was wrong with mine anyway and what it sounded like
873Stang
221
riverside
Mar 21, 2007
  • Mar 21, 2007
it sounds like in between the trans and motor its a 5spd
Aryan15
236
CA
Mar 21, 2007
  • Mar 21, 2007
Check your motor mounts
JChalfan
551
Bellevue, WA
Mar 21, 2007
  • Mar 21, 2007
Did the noise start at the same time you installed the clutch quadrant?
Did the noise start after you did anything in specific, or did it just show up out of the blue one day for no reason?
Jeff
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Mar 21, 2007
#10
  • Mar 21, 2007
  • #10
Check the plate that goes between the tranny and the engine..
873Stang
221
riverside
Mar 21, 2007
#11
  • Mar 21, 2007
  • #11
well before i instaled the quad
after i put marvel mysterie oil in
notice motor mounts are shot
and then piece of metal (sheield) on the cats are broken off
by the way how can i fix my starter it sounds like its binding up
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Mar 21, 2007
#12
  • Mar 21, 2007
  • #12
check your timing.. if it sounds like its binding up, and your having detonation.. it could definately be timing
ninety15.0
1,336
#13
  • Mar 21, 2007
  • #13
dude you gotta be more detailed when you ask questions on here. Im not trying to be a dick...but we need more specifics. Secondly a chattering metal on metal sound thats comming from between the trans and motor does not make me think detonation?!?! Detonation sounds like a couple pennies bouncing around in a tin can and should be comming from the motor only. Sounds like a clutch issue...perhaps a throw out bearing or too much slack in the cable? Does it happen at a specific rpm or anytime at WOT? When the car is cold or hot...or anywhere in between? Every gear? Give as much info as possible and we can try to point you in the right direction. Also if the motor mounts are shot that may mean that the motor is not sitting in the correct position in the car which could be causing some of your problems. Rip that heat shield off the car or weld it back on...but do something to eliminate that as a possible cause for the rattle. let us know and good luck
873Stang
221
riverside
Mar 22, 2007
#14
  • Mar 22, 2007
  • #14
so i figured part of it out lol
so i figured out the noise it was a header bolt that backed out and fell in between the the header tubes!!!!!!
but not im trying to figure out how to make my started not sound so bad its brand new, and the cloud of white smoke i get when i gas it hard along with the strong smell of un burnt fuel.
thx for the help guys and gals
Electrical MSD Blaster TFI Coil 8227 loud Chirping Noise.
  • PonyGTrider
  • May 25, 2025
2K
Fox 5.0 Mustang Tech May 31, 2025
PonyGTrider
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Fox Power Loss While In Gear
  • J_5.0_VERT
  • Dec 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2024
J_5.0_VERT
What is this noise?!
  • squirrel0420
  • Jul 3, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 4, 2025
horse sence
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
