under boost at high rpm, boost needle shakes fast, any ideas?
  • Thread starter Thread starter Foxfan88
  • Start date Start date Sep 9, 2007
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Sep 9, 2007
  • Sep 9, 2007
been working on my car had some running issues, got it running decent and got a good pull on the back road. the powerpipe i installed works real well it seems
one time in 2nd gear i was turning maybe 5400 or something, its was up there and i made about 7 psi but the needle started shaking, going up and down about 2 psi really fast.
could this be valve float or something, because i dont feel anything, just the needle on the boost gauge shakes violently. only happened once so i am not sure.
but i could tell a difference with the boostmaster pipe, the car was hauling ass.
D
Djstorm100
109
  • Sep 9, 2007
whats boostmaster pipe suppose to do? or the powerpipe? link
is it electirc or is it mech guage?
BLOWN 5.0 FOX
213
NORTH SHORE MA
Sep 9, 2007
  • Sep 9, 2007
sounds like compressor surging
kbeefy
29
  • Sep 9, 2007
^^ yeah. My truck does that under heavy load. Does it make any noise? Sound like a turkey?
If it's surging, it's stalling the intake airflow and creating a shockwave, basicaly your cavitating your impeller.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Sep 10, 2007
  • Sep 10, 2007
any way i can stop it? i dont hearing anything i dont think...
and the boostmaster pipe is the same as a power pipe, its pretty much a cold air tube for the blower
BLOWN 5.0 FOX
213
NORTH SHORE MA
Sep 10, 2007
  • Sep 10, 2007
poss defective and or poor vac to your bypass valve... if your using one...if your not... get a bypass valve. Basically when your throttle is shut aka shifting etc, the boost has no where to go but "back" to your compressor creating pressure in the discharge pipe. A bypass vents that pressure to before the blower which in turn recycles the air without creating pressure. Good luck!!
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Sep 10, 2007
  • Sep 10, 2007
i dont have a bypass, i guess it is surging, i didnt realize this.
but it seemed like it happen before i shifted maybe i was shifting i duno
TheBocSez
652
Converse, TX
Sep 10, 2007
  • Sep 10, 2007
If your seeing over 5-6lbs, a bypass would be a good investment for you.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Sep 11, 2007
  • Sep 11, 2007
got it ordered last night
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
Digital Self-tuning Forum May 1, 2026
X-cam34
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
