Well this morning was the first time I took a good look under my 88gt 5 spd mustang and I noticed a lot of grease/oil/tranmision build up around the oil pan all the way back to the u-joint. I can understand grease flun around the u-joint , but I also had a lot of build up on the transmission. I checked the transmission level it was find. Can a leaking gasket on the oil pan cause that much of a mess all the way back to the tranny. Also, I don't know a lot about the transmission, but I saw a rubber mount under the tranny, I supposed to dampen vibration, but I could grab the drive shaft where the u-joint is and slightly move the transmission, and when I would move it there would be a slight clunking sound. Is this normal? How often do those rubber mounts go bad? Could this explain the thumping noise I hear whenever I shift into first?
Thanks for the help........
fost9508
fost9508
