  • 1994 - 1995 Specific Tech
underdrive pulleys
  • Thread starter Thread starter rulesR4suckers
  • Start date Start date May 17, 2007
R
rulesR4suckers
72
Fairview Heights, IL
May 17, 2007
  • May 17, 2007
So, lately I've been hearing this noise coming from my alternator that sounds like the bearings were about to go. Hearing that, I decided to order a set of underdrive pulleys and make project for myself. I took the old alternator off and just as I was about to pull the pulley off of the new alternator, I noticed that the pulley was the same size as the pulley that came in the underdrive kit. Has anyone else run into this? I thought it was weird, but it saved some time though.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
May 17, 2007
  • May 17, 2007
Mine was smaller, but only about 1 MM if that. most of the size difference is in the other two pulleys. Id leave the stock alt pulley so you have less of a chance of charging issues.
True 5.0
237
Southeastern Wisconsin
May 17, 2007
  • May 17, 2007
Most underdrive sets have the alternator pulley much LARGER than the stock one. The concept is to slow down the RPM's of the accessories relative to the crank RPM's. My set has a smaller than stock crank pulley and a larger than stock water pump and alternator pulley. All the others do not get replaced and thus are stock diameter. I'm not sure how the alternator pulley can be smaller and still run the stock belt.
R
rulesR4suckers
72
May 17, 2007
  • May 17, 2007
Yeah, I'm definitely not messing with the alt pulley. Since it's the same diameter I don't see a point in changing. I'll say this, I have noticed a bit of a difference in power. The interior lights dim a bit at night with the headlights and radio on, but I can deal with that.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
May 17, 2007
  • May 17, 2007
I would tell you to just keep the OEM set if you're not gonna use the
entire set of pulleys.
The whole reason for the mod is to gain power
This mod yields small gains at best
but
Never the less ... its a nice one for the money spent
By not changing the alt pulley ... the gain is gonna be less for sure
You can find a bit more juice at idle with just 1 to 2 hundred more rpm
Now ... If you got a mega watt pulling sound system ..........
You shouldn't even be considering them in the first place ... IMHO
Grady
Engine Underdrive pulleys
  • Mindseye007
  • Feb 1, 2026
Fox 5.0 Mustang Tech Feb 14, 2026
Willybill32
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
