Underdrive Pullies Help!!
93tealstang said:
I'm not completely sure but I think a 14mm socket will work. Or else a phillips head screwdriver. No need to remove anything either.
no sir, you think you can get a socket wrench or screw driver in with the fan and junk still on? :rlaugh: i had to take mine out with the shroud to get a socket wrench in there. and it was still PITA.
Icepick said:
lol, good one :) Kind of hard to change the water pump pulley without taking the fan and shroud off.
You don't have to remove the shroud. After taking the belt off then remove the 4 bolts attatching the fan's hub to the pulley and slide it to the side.
