underdrive pully
  • Thread starter Thread starter Ryan91Saleen
  • Start date Start date Jan 2, 2004
R
Ryan91Saleen
173
Washington
Jan 2, 2004
  • Jan 2, 2004
i have a stock alternator will i need to get a new one or will mine be ok it goes down yo 8 at idle
Mavrick
2,264
Collingwood, ON
Jan 2, 2004
  • Jan 2, 2004
I think it should be fine, i have an underdrive crank and waterpump pulley... my alt. charges at 14.6v at idle without the lights on etc.
R
Ryan91Saleen
173
Washington
Jan 2, 2004
  • Jan 2, 2004
whats your idle at night time
Mavrick
2,264
Collingwood, ON
Jan 2, 2004
  • Jan 2, 2004
I don't remember if i had the multimeter on it with the lights on. I would happily test mine for you, but the car is in a garage and i don't plan on starting it .
This was also tested when my idle was below 750RPM.
Don't forget that stock alt's differ from one another, do they not? One is 65amp and the other is 95amp? I don't know which one i have.
R
Ryan91Saleen
173
Washington
Jan 2, 2004
  • Jan 2, 2004
hmm ok
1hot5.0
1,615
Surprise, Arizona
Jan 2, 2004
  • Jan 2, 2004
You should be ok as long as you dont have your a/c on with your headlights and all.
Worst case senario:, you need to get an ASP alternator overdrive pulley. It is 1 7/8 in size, where the stock is 2.1/4 I think??? If you find out you need it, you can order it from summit racing for about $30.
Engine Underdrive pulleys
  • Mindseye007
  • Feb 1, 2026
Fox 5.0 Mustang Tech Feb 14, 2026
Willybill32
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Electrical Starter solenoid green wire?
  • 387lx
  • Jun 1, 2026
Fox 5.0 Mustang Tech Jun 2, 2026
AeroCoupe
