I have pullies on my crank and water pump, charges fine and cools perfect, run about 198 most of the time if not 195 on the dot on the highway with a 195 thermostat, thats with my mods and stock cooling system. For the main question we've dynoed lots of different cars with the dyno at my school (brand is superjet, or dynojet or one of those) when I first put my car on, i was at 275, then I made 273, then I made like 276 or something like that all without changes, the numbers were all over the place, and all the other vehicles we've dynoed were never consistent, it also depends on how you run through the gears, well how we did it was climb through the gears, once u got to a certain speed in 4th gear (1:1 ratio) you would punch it, if say u had to punch it at 45mph, if u climbed up to speed real slow, like 42..., 43..., 44..., then as soon as u saw 45mph then punch it, youll probably have a slightly different reading as if u went say 41,42,43,44, then 45 then punched it, I no that was a crappy way to explain it but if u do it at a faster rate like my second example theres already momentum built up and it will help out the motor to get the rollers going. I think thats what helped mine be non consistant, (also normally after the 2nd run the numbers start slightly going down from the combustion temps getting so high) the dyno just counts how long it takes to spin over the rollers (since they are a certain weight, I forget how much ours weighed) in a certain amount of time and then calculates it and tells u the horsepower, the one we use just uses a big truck rearend.....before we use it for the day we have to warm the differential fluid up to a operating temp, like 105 or so, if its say 75 that will give a slightly different reading im sure, also the air temp makes a difference, it seems like u never get the same numbers in a consistant run, especially if say u get 270rwhp at one shops dyno then u might make 278rwhp at another dyno, it never seems to be the same numbers from dyno to dyno....My teacher said some places might edit the program a little so the car will have higher numbers than what it really has, say by putting in a different air temperature reading or something since it takes into consideration all that. Also last time I dynoed it I ran through all the gears the Exact same, shifted at the same rpm, took the same amount of time to get to my starting speed, did everything the exact same and my numbers were all consistant, my first run was 279.9, 2nd run was 280.6, and 3rd was 280.1rwhp....BTW Im just talking about a inertia dyno, since thats what we used......theres the other type which used a braking device to load the rollers, and im sure u get the idea.....none of this probably helped but just thought I would share my experiences.....
