Ok, the car would die sometimes, or not start sometimes. Replaced the TFI, worked a little bit...but no...kept doing the same thing.
Took it off, and tried a thicker coat of dielectric grease...then it would not start at all.
Now, tried a pretty thin coat of it, and it worked about the first 20 starts..then died while driving. Wouldn't restaret. Tried about an hour later, and it started, and has worked perfect since (about 3 starts).
Is there a way to eliminate this ridiculously touchy part? Like a different ignition...or distributor...or something? Should I funnel air onto it to help cool it? Tips?? Help??
By the way...this is the passenger fender mounted TFI.
