Updated Engine Pics...
  • Thread starter Thread starter REPLIMOD #17
  • Start date Start date Mar 17, 2006
First Prev 2 of 2
R
REPLIMOD #17
52
#21
  • Mar 24, 2006
  • #21
4MuscleMachines said:
I know those are fabricated valve covers, but what brand?
Acutally those were made by an individual that I found on Ebay.
He sells them without the breather tubes and oil filler, but he can install the extras for a little more money. Do a search on ebay for SBF fabricated valve covers and you should be able to find them. Remember they are extra wide so make sure that you have plenty of clearence...
R
REPLIMOD #17
52
#22
  • Mar 24, 2006
  • #22
xoxbxfx said:
can you do a rundown on the specs of the car?? I like the IRS
I'm working on a write-up with all of my specs and parts, and I should be posting it within the next month or so as I finish the project up. I'll also try to put together a photo gallery from start to finish...
C
C0V3R
524
Australia
Mar 26, 2006
#23
  • Mar 26, 2006
  • #23
Thats a beautiful motor you have there!
F
fastback brian
540
So Cal , I.E.
Mar 26, 2006
#24
  • Mar 26, 2006
  • #24
colorfull setup. Im intersted as well with the engine specs. Maybe you could dress that engine up a bit with a csi tstat housing and a billit front cover and water pump.
M
mikemustang289
224
mesa, az
Mar 27, 2006
#25
  • Mar 27, 2006
  • #25
Very Nice, if that is your first Biggs carb then don't worry, it will work flawlessly, I had mine built by him and it works perfectly, he does amazing work.
I have a question about the vavle covers though. The 302 I am putting together will have AFR as well, which should arrive in a few weeks, but I'm looking to go with fabbed covers cause my oil pan is Fabbed aluminum as well and I wanted something that would match
Do these covers have billet rails? I've heard others have problems with leaks because some of these covers aren't made with thick flanges and they will warp or don't sit flush. Also, what kind of breather can you run with the tubes? I currently have regular covers and at high RPM's I still get oil that finds it's way out, I think placing the breather up high like that would solve this problem.
R
REPLIMOD #17
52
#26
  • Mar 27, 2006
  • #26
The Covers do not have billet rails, but they seemed to mount up very tight with no warping. If you shop around there are lots of fabed covers out there with billet rails to be had.
The longer breather tubes will take a 1.5" clamp on breather which you can pick up at most any local speed shop. Hopefully I want have any oil blow by, but depending on your setup there is always that possibility especially at high RPM's. If it becomes a problem a puke tank should solve it.
First Prev 2 of 2
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
R
Progress Thread A small update on our first-gen Mustang project
  • Restomotive
  • Apr 24, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 24, 2026
Restomotive
R
Help Me Build a 289
  • 66Stang1
  • Sep 18, 2025
Classic Mustang Specific Tech Sep 18, 2025
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
