updated Shaker TSB
afixer
The Informant
Apr 3, 2005
380
so i noticed an update on the shaker radio prob. i wish we would have seen this when i replaced mine it took 3 calls to ford before my friend and i fixed it. this tells the tech how to reprogram the mod with the WDS unit
maybe this helps
INTERMITTENT CD PLAYER CONCERNS—AUDIO TSB 05-10-19
UNIT PROGRAMMABLE MODULE INSTALLATION
(PMI) REQUIREMENTS
FORD: MERCURY:
2005 Five Hundred, Focus, Freestyle, 2005 Montego
Mustang, F-150
This article supersedes TSB 05-06-09 to update the If communication cannot be established with old
service procedure. audio unit to download this information or if old
audio unit is not available, as built data will need to
ISSUE be entered. Use NGS+ or PDS scan tool to
Some 2005 vehicles built before 2/24/2005, and complete the operation or follow the procedure
equipped with a 6 disc CD player with MP3 below using WDS:
capability (e.g. radio must have MP3 logo present),
1. With radio (ACM) DISCONNECTED, start a may exhibit one or more of the following intermittent
new WDS session (delete existing session if CD player concerns.
started).
• CD player skips repeatedly
2. After WDS identifies the vehicle, select Toolbox • Locks up when playing certain homemade CDs
> Module Programming > Programmable • Displays “Error” or “Bad Disc” repeatedly
Module Installation > ACM.
• Will not accept CDs
3. Follow WDS prompts, connect radio (ACM) • CD inoperative or inconsistent playability of some
when prompted to “install new module”, hit tic CDR media
mark to continue.
ACTION
4. WDS will prompt for as built data. Enter as built
• Obtain detailed description of symptoms reported data and finish following prompts until “module
by customer. configuration successful” is displayed.
• If issue only occurs with a specific CD, examine
As built data can be obtained at the Professional the CD causing the concern. Confirm that it is in
Technician Society (PTS) website or at good condition (e.g. CD is NOT chipped, warped,
www.motorcraft.com. For additional information, scratched, labeled, or contaminated).
refer Workshop Manual Section 415-01 and 418-01.
• Replace radio with latest service level through
your facing audio service center. PART NUMBER PART NAME
SERVICE PROCEDURE -18806- Audio Unit
When replacing the audio unit (radio) on 2005 WARRANTY STATUS: Eligible Under Provisions Of
Freestyle, Five Hundred, Montego and Mustang
New Vehicle Limited
vehicles it is necessary to perform programmable
Warranty Coverage
module installation (PMI) prior to removal of the old OPERATION DESCRIPTION TIME
audio unit. This information must be uploaded into
051019A 2005 Five 0.7 Hr.
the new audio unit once installed. Failure to perform
Hundred/Freestyle/Montego:
PMI on the new audio unit may result in inoperative
Replace CD Player (Do
backlighting and/or diagnostic trouble code (DTC)
Not Use With 18805B Or
B2477. It is not necessary to perform PMI on the
18805C)
F-150 or Focus.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do
the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper
vehicle service. The procedures should not be performed by “do-it-yourselfers”. Do not assume that a condition described affects your car or truck. Contact a
Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation
determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article.The information in this Technical Service Bulletin
(TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates.The most recent information is
available through Ford Motor Company’s on-line technical resources.
Copyright ã 2005 Ford Motor Company PAGE 1
TSB 05-10-19 (Continued)
051019A 2005 Mustang: Replace 0.9 Hr.
CD Player (Do Not Use
With 18805B Or 18805C)
051019A 2005 Focus: Replace CD 0.4 Hr.
Player (Do Not Use With
18805B Or 18805C)
051019A 2005 F-150: Replace CD 0.3 Hr.
18805B Or 18805C)
DEALER CODING
CONDITION
BASIC PART NO. CODE
18806 42
PAGE 2
I got my Mustangs shaker 500 replaced with the revised version a little less than a month ago... but even the revised "B" version still skips a little. Is this TSB anything different than the one that tells you to swap out for a different "B" version?
by programming update do you mean something that the dealer does besides replacing the system to fix the skips? I have the "revised" version, but it still seems to skip some CD's. Is there anything to help me..?
yea some cars wouldnt accept programing from the WDS when the radio was replaced and the light would not dime on the radio when the lights were turned on. this fixes that
