  • SN95 4.6L Mustang Tech
upgrading axels
  • Thread starter Thread starter 04gtdrop
  • Start date Start date May 12, 2006
1 of 2 Next Last
04gtdrop
532
Sac, CA
May 12, 2006
  • May 12, 2006
ok, so i'm thinking about upgrading my axel's. What do you need to get this job done?
Odds are i will be doing this at my freinds house. He has all the air and hand tools that we might need. I'm just trying to think ahead. If i go ahead and buy the 31 spline axles, are their other parts that i need to buy to complete or smooth out this install?
:SNSign:
steveb24
555
wilmington, DE
May 12, 2006
  • May 12, 2006
im wondering the same thing..lets put this up top. i think on jegs theres an axle bearing kit or install kit for axles..something like that..not sure tho
spdfrkaby
82
Minot, North Dakota
May 12, 2006
  • May 12, 2006
All I know is that you would need the 31 axles and a 31 spline trac loc/posi whatever it's called and maybe upgrade the gears if not done already
Mossberg
ATL, Shawty
May 12, 2006
  • May 12, 2006
You'll need a new 31 spline diff, axles, and of course, throw some 4.10s in there while everything is apart.
C
CENTENNIALSTANG
Houston
May 12, 2006
  • May 12, 2006
How much will all that cost?
04gtdrop
532
Sac, CA
May 12, 2006
  • May 12, 2006
yeah, thats what im trying to figure out.... i already have 3.73 gears back there. But the rest is stock. I found a "kit" that does not include the spline diff. Its like 300 bucks or so... its made by "Superior Axle & Gear" have you guys heard of them?
i want to save $$$ but i also want good parts, not crappy stuff that will break. I would rather put out a lil more $$ up front to save a headache later on, ya know?
steveb24
555
wilmington, DE
May 12, 2006
  • May 12, 2006
i didnt think u had to get a new differential for 31 spline axles.. can anybody clear that up?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
May 12, 2006
  • May 12, 2006
dont forget about the speed sensor ring that goes on the axles those have to be pressed out and pressed in to the new ones and becareful not to damage them
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
May 12, 2006
  • May 12, 2006
when you do a 31 spline upgrade everything must be replaced meaning the axles and diff cause they are a 28 spline from the factory so a 31 spline axle wont go into a 28 spline diff
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 12, 2006
#10
  • May 12, 2006
  • #10
you will need a 31 spline diff. you will also have to swap out the ABS rings if you have ABS. also you will want to replace all of the bearings and seals. this is also the time to use studs on the caps in the diff and to put on a diff cover and cooler(if you road race). you will also need to have new wheel studs pressed in. you can reuse the gears if you want, however you will have to buy new bolts to attach the ring gear to teh differntial, those are one time use only.
all in all you are looking at about $1200-$1600 depending on the quality of parts.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 12, 2006
#11
  • May 12, 2006
  • #11
you can also go with the diff out of a ford truck 8.8 with limited slip. some of the lower end F-150 came with a rear end like that. Highline F-150 for the most part had the 9.75 rear
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
May 13, 2006
#12
  • May 13, 2006
  • #12
off of topic bit. But how about just change axle to stronger axle thats 28 spline? i think Moser(Summit PN#MSR-A882841)makes 28splin axle that are forged steel, and much stronger then stock 28 and Superior(Summit PN#SAG-EV81-28)makes 28 splin axle that are made from a super-tough, induction-hardened alloy for like around 250bucks.
I know that 31 is the way to go if you drag race your car all the time. But for what i use my car for, i can't justify replacing carrier. just so that i can get stronger 31 spline axle...
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
May 13, 2006
#13
  • May 13, 2006
  • #13
That is what i did,swapped out the stock axles to the mosers 28 spline axles.I figured that i'm not gonna make huge power,and don't plan on using drag slicks besides drag radials,and that is how i based my descission.When the centre section does decide to go,then i will up grade everything then.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 13, 2006
#14
  • May 13, 2006
  • #14
i have the 28 spline Mosers. they are perfectly adaquate for my power level and style of driving. i dont do hard launches, and cornering at over 1g doesnt require 31 spline.
04gtdrop
532
Sac, CA
May 13, 2006
#15
  • May 13, 2006
  • #15
how much power, TQ and abuse can some moser 28 spline's handle?
D
DerekStangGT
My package is in the mail!
Feb 18, 2003
1,068
May 13, 2006
#16
  • May 13, 2006
  • #16
what is this cooler you speak of?
mity2
Jul 24, 2003
2,872
StateCollege PA
May 13, 2006
#17
  • May 13, 2006
  • #17
I remenber reading about diffrential cooler on either 5.0magazine or FF&MM while back.
I think KennyBrown made the kit
I've also found this. its really an over kill. But its pretty trick set up
http://www.timskelton.com/lightning/race_prep/reliability/differential.htm
D
DerekStangGT
Feb 18, 2003
1,068
May 13, 2006
#18
  • May 13, 2006
  • #18
wow, thats unnecessary to say the least
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 14, 2006
#19
  • May 14, 2006
  • #19
on a lot of hte clutch type limited slip diffs, they tend to run very very hot when pushed hard road racing. they run so hot that the clutches give out after 3 or 4 track days. even the carbon fibre 03/04 cobra style ones.
also a lot of pure track cars will have a cooler for the manual trans fluid.
04gtdrop
532
Sac, CA
May 14, 2006
#20
  • May 14, 2006
  • #20
well my car is not road raced, she see's the 1/4 mile track from time to time, and i beat up on her pretty hard on day to day driving...
that cooler is pretty sweeet, but looks like a bit over kill...lol.
anyone else got anything?
thanks for all the post's so far SN!
1 of 2 Next Last
Hi. I'm new. 98 Cobra Bent Axle.
  • sbk93036
  • Mar 28, 2026
SN95 4.6L Mustang Tech Oct 5, 2026
Mustang5L5
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
