Upper control arm movement
65fastbackresto
1,229
AR
Me and a buddy were checking the front end components, had car jacked up, and we were shaking the front wheel. The only movement I could see was the upper control arm would move in and out about 1/8th to 1/4 of an inch. That was applying pressure on the top and bottom of the tire, wiggling it so to speak.
This car roadwalks quite a bit, does anyone else think this could be a contributing factor?
I kinda figured that I`d have to replace something.
Ok guys, so far here`s my parts list for the front coil spring project.
620 Meiyer racing springs.
Spring perches. Prob gonna upgrade to roller perches before I start.
Isolators, 2 pair, 1 1/4 thick set and 1 1 inch set, so I can raise or lower the front end.
Gonna get a new set of upper control arms to keep from having to do this again later.
Shelby drop template.
Am I forgetting anything I`m gonna need to avoid having my car tore apart for weeks.
Don't forget the beer.... oh and check and see if you need new inner/outer tie rods, see if your shocks are blown and check the lower control arm to see if it is worn out too.
