Well, they really won't have much choice since you had it all apart. Frequently, they just set the toe and call it good, at least at the cheapie places. Old saying in the biz..."set the toe, collect the dough, let it go".
One issue to be aware of..I have found that often you have to double up on the strut rod bushing washers (install 2 washers, then the bushing) to get the ball joint far enough forward to be able to get both caster and camber in spec. Seems that as the cars age, the bushings that hold the strut rod mounts allow the mounts to go back slightly. This results in the outboard end of the lower control arm being too far back. It's apparent on many IIs in the form of the wheel being rear of center in the well when viewed from the side.
I use later fox body springs in mine as I find the OE spring rate too low for my taste. I generally use a 4 cyl '84 or so spring. The rate is quite a bit higher, the spring diameter is within a few hundredths of the II spring, and a side benefit is that they are usually slightly shorter, which makes installation easier. I generally install the upper arm/spindle, then install the lower arm into the crossmember, then jack the outboard end up and install the nut on the stud. I do have access to a lift, so that helps as opposed to rolling around on the ground.
Oh yeah, ALWAYS ask for a spec sheet (printout) of the before/after settings (at the very least, the after) when you drop the car off. Make sure to ask before they do the alignment. Many shops routinely print them, but most do not, unless you ask. If they won't provide one, find another shop.
Lastly, don't assume that everybody understands the concept of the angles in an alignment. The local Goodyear store has no clue whatsoever, nor do most franchised tire dealers (Tires Plus, etc). There are exceptions of course. We had to teach the shop that we use at work how to diagnose suspension problems as they relate to collision repair. You wouldn't believe how many times I've heard "frame damage" when the actual problem was a suspension part. Got so bad at the last shop I worked at that we bought the equipment and (I) started doing them in-house.
