- Nov 24, 2010
- 5
- 0
- 0
bought car a week ago so i dont know the history but it is a 97 4.6 it has a professional products throttle body and intake plenum and k&n filterkit
the noise is all the time sounds like a tensioner of idler squeek. i removed the belt and the noise is still there so that eliminates everything on the front of the motor. appling th clutch makes no difference. the noise is there hot or cold and every rpm. it sounds like it is coming from the drivers upper rear part of the engine like a bad rocker arm roller bushing. i removed that valve cover had my mechanic check all the rockers they were fine, also like to mention i am a ford service manager and none of my mechanics have heard this noise before.
any ideas? could it be the flywheel rubbing the dust plate and the noise just resonating?
thanks to anyone in advance!
