Suspension upr torque box reinforcement plates
MikeH686
Mine is only two inches though.
2,843
1,753
184
Waldorf, MD
Need some help with these things ive got both upper and lower reinforcement plates so i started on the lowers because they are a bit easier to get to for me so my problem is the way i have this box that goes inside the frame rail the hole that is suppposed to align with the exsisting hole for the control arm doesnt line up and ive tried both reinforcement boxes so i guess my question is does anyone have a pic of how they orientated it to get the box to line up?
Thats what im saying the hole to put the control arm bolt through to hold the reinforcemebt plate doesnt line up so i mean i put in the pass through hole like they said in the direction thought it was misaligned because of a body plug took the plug out and its still mis aligned
you tried flipping them around side to side? its been a few years since i did mine so i dont remember exactly what i did
Yeah i tried flipping them between the two left and right yes the car is completely apart including those plugs but it seems like they are a 1/4" to low on both boxes but i can tell that alignment left and right on both is correct its just that both are to low
a guy i work with has a drawing that he made his off of. but hes out today, if you dont have it figured out by monday i'll get that from him and you can measure yours to make sure they didnt get stamped wrong
Thats what im thinking because also the plate side for the upper the curved piece of flat steel one is either not curved enough or the other one is curved to much they both aint the same
you might have to get out a hammer, torch and a drill. we did some of these on my buddies car (bolted them in first, then welded them) and they were a bigger pain in the ass than the wolfe weld in plates and just welding the upper torque boxes we did to my car. that being said, we havent had any problems with either running 1.3 60' times.
I had the same problem on the Hoopty build. Ended up having to drill the hole out on one side and weld the other side to make it work right. Dearch for teh thread and youll see what I did. I think the pics are in there...
I fixed it i just expanded the hole a tad but it was only on the driver sidr box passenger side fit like a glove oh well all done and fixed now just gonna weld them up and start putting interior back in
I had the same problem, bought my kit from lmr though. I ended up reaming the driver hole and it still didnt fit. I then had to use a bottle jack in the corner of the plate to straighten the box out. Bolted the control arm bolt in and all is well
