I ran into some problems today trying to get the right pushrod length..
First off, the block is stock and the heads are stock from TrickFlow.
I purchased a pushrod length checker form TrickFlow and for some reason, I'm getting different lengths for different valves. I know what you're thinking. But the lifters are all the way down. I honestly don't know if I'm doing the process correctly or maybe my lifters are bad?!?!
Basically, I'm installing the adjustable pushrod between the lifter and the 1.7 rockers. Then, I'm making sure the adjustable pushrod is closed all the way. Then, I install a rocker on a head stud and begin screwing the adjustable pushrod until there's no play up and down. I then get under the car and turn the crank a few times.
I've done this for three different valves and only two ended up with the same measurement. I've noticed TrickFlow says to use 6.750 rods and my rod measurements fall below 6.700?
Does increasing the rocker ratio from 1.6 to 1.7 warrant a shorter pushrod?
I've looked at Comp Cams, Crane Cams and others with no idiots guide for doing this and knowing it's been done right. Anyway, it's getting late here in California and I was hoping somebody might help me out with this. Please help if you can guys! -Bill
