use 96 intake with a 2002 motor
rockyracoon
874
27
49
margate NJ
I just noticed that the plastic outlet for coolant that comes out of the passenger side rear intake is broken up where the rubber hose begins.they must of broken it when they removed the motor.can I use the older intake?
I see that the intake gaskets for the two motors have a different part number,hence I assume the intakes differ slightly.
I have a PI engine that im in the process of installing,but as stated in the thread, the plastic water outlet is damaged,thats why I was asking about using the intake from my 96.
BTW my 96 intake has the aluminum crossover.
Are you willing to give up a solid 25hp? Because that's what you'll be leaving on the table swapping a pre-PI intake, to your PI engine. Spend the $200 on the proper intake and don't look back. This is not an item you want to start cutting corners and saving pennies with.
:stupid:, why, just why:jaw:? I'm as thrifty as they come when comes to looking for a deal on car parts, some things are best left as they were built, move forward, this is something you will regret, don't drive unless its your daily and just save for it and do it right!!!:(
