Put a fuel pressure gauge on the Schrader valve on the fuel rail & see what kind of pressure you are getting. You are going to need one with a supercharger, so you might as well do it now.
Replace the fuel filter since changing the pump often shakes loose dirt that can clog the filter.
Next, dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See
http://www.troublecodes.net/Ford/
OR
See
http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See
http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see
http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Look for codes 95 & 96 which are fuel pump electrical system problem codes.
