Using Pushrod Length Checker
  • Thread starter Thread starter srjs28
  • Start date Start date Jun 27, 2010
srjs28
69
  • Jun 27, 2010
looking for a write up or site on how to correctly check for pushrod length with adjustable rod. do i have to use a mechanical solid lifter for this procedure and when checking piston to valve clearance? i guess i could buy just a cheap one from local auto parts.
PoppyMod
617
Severna Park, MD
Jun 27, 2010
  • Jun 27, 2010
I bought mine from CompCams. Very useful and much needed tool to get the geo. correct. It's adjustable in .050 increments. With check'g springs, I did not need to use a solid lifter. The springs are soft enough as to not compress the hydraulic lifter.
BYRDPE
1,556
Memphis,Tn.
Jun 27, 2010
  • Jun 27, 2010
Setting Pushrods Length, Quick and Easy- Car Craft Magazine
you can turn one of your lifters to solid by taking it apart an insert a small nut then reinstall the retaining clip. reassemble when done.
srjs28
69
  • Jun 27, 2010
i already have the length checker, just looking on how to use it correctly. i do have check springs that came with my cam degree and dial kit. so if i use the soft springs i can use my hydraulic roller lifters and not have to purchase a solid lifter?
srjs28
69
  • Jun 27, 2010
do you have any more detail to this procedure? i have never disassembled a lifter before. and where do you put the nut? thanks
BYRDPE
1,556
Memphis,Tn.
Jun 28, 2010
  • Jun 28, 2010
use this one...it shows better details.
Strokers Wild: Part 1
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
