V3 Almost!
  • Thread starter Thread starter smkshw
  • Start date Start date Aug 2, 2015
  • 14
  • 15
  • 16
  • 17
  • 18
  • 37
First Prev 16 of 37 Next Last
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
Aug 26, 2015
#301
  • Aug 26, 2015
  • #301
well,all that work for nothing.....still water in the oil.....im lost guys,i did all the tests that i know of?.......where is it coming from??....i realy need your help plz!,because im lost now??
TOOLOW91
20+ Year Stangneter
8,753
234
S.I.NY
Aug 26, 2015
#302
  • Aug 26, 2015
  • #302
Cracked block or a bad HG is my guess
Reactions: A5literMan
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
Aug 26, 2015
#303
  • Aug 26, 2015
  • #303
but i did the leak down test?....and rad test?....i dont get it?
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
Aug 26, 2015
#304
  • Aug 26, 2015
  • #304
i know im pulling the heads now but is there anywhere else it could be coming from?....my oringinal guess was head gasket also but everything checked out????
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
Aug 26, 2015
#305
  • Aug 26, 2015
  • #305
im ready to order a short block straight from ford but my luck it will be heads!!
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Aug 26, 2015
#306
  • Aug 26, 2015
  • #306
Leak down won't show a cracked block unfortunately. Not saying this is for sure your problem. But most likely either the head gasket or block is compromised. Unless there is something I'm missing. Just sucks man. I feel for you.
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Aug 26, 2015
#307
  • Aug 26, 2015
  • #307
If it is the block I highly recommend just going straight to an aftermarket block(dart-boss). Then you could just transfer everything over and not worry about the block again. Also you can turn the boost up(obviously with the proper mods/tune). You could check FordStrokers.com and talk to the owner Jim Woods(Woody). He could sent you a machined block. Etc. Expensive but....
Reactions: TOOLOW91
TOOLOW91
20+ Year Stangneter
8,753
234
S.I.NY
Aug 26, 2015
#308
  • Aug 26, 2015
  • #308
My buddy had the same issue . Was getting milky oil but no signs of anything wrong . Found a crack in his block (ford FE motor ) spoke to an old timer and he repaired it and hasn't had a prob . in this situation with a stock 302 if that's what it is - pull and do a dart block and change the Pistons . If your already there
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Aug 26, 2015
#309
  • Aug 26, 2015
  • #309
And I always like spending other people's money lol. You're living proof lmao. Signed Asmybrokeasskeepsmessingwithastockblock
Reactions: stang89bidges and TOOLOW91
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Aug 26, 2015
#310
  • Aug 26, 2015
  • #310
so you did the following
exhaust gas coolant test
compression test
leakdown test
all came back good?
when you pulled the intake did you look in the intake valley and down the front for any cracks? Did you check the oil galley plugs?
Sorry man but think it's time to pull the heads. You may also need to pull the timing cover to check for a cracked block. Only thing I can think of is adding dye to the coolant to see if you can find the crack. They sell UV dye and black lights.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Aug 26, 2015
#311
  • Aug 26, 2015
  • #311
Not to sound like an ass, but you did change the oil after the reinstalling the intake? You will get coolant in the oil when pulling the intake.
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
Aug 26, 2015
#312
  • Aug 26, 2015
  • #312
ya fresh oil
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
Aug 26, 2015
#313
  • Aug 26, 2015
  • #313
compression test
leakdown test
all came back good?
compression 185 all
rad test negative
leak down test 90psi in held 85psi for a couple mins
didnt check for cracks?
and saw one galley plug on the top it was in is all i can say
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
Aug 27, 2015
#314
  • Aug 27, 2015
  • #314
i cant beleive im doing this but pulling heads this weekend....i learnt how to do rockers on the fly,but head first time for me also?....any tips guys before i get started?
TOOLOW91
20+ Year Stangneter
8,753
234
S.I.NY
Aug 27, 2015
#315
  • Aug 27, 2015
  • #315
Take your time and work orderly and keep it all as clean as possible
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
Aug 27, 2015
#316
  • Aug 27, 2015
  • #316
ok ill give it a go,i just want to find a definitive answer already!
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
Aug 27, 2015
#317
  • Aug 27, 2015
  • #317
all i no is my rad is not over flowning with pressure,its just loosing water,i can see a bubble every so often and it starts draining basictly??!!!
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Aug 27, 2015
#318
  • Aug 27, 2015
  • #318
Almost sound like mine when i blew a timing cover gasket.
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
Aug 27, 2015
#319
  • Aug 27, 2015
  • #319
really?....how did you find out?
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
Aug 27, 2015
#320
  • Aug 27, 2015
  • #320
theres water coming from somewhere,but im stumped!....dont want to tear it all appart and find it was somthing else!
  • 14
  • 15
  • 16
  • 17
  • 18
  • 37
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
