V3 Install Under Way Finally
  • Thread starter Thread starter JD1964
  • Start date Start date Oct 5, 2015
  • 3
  • 4
  • 5
  • 6
  • 7
  • 11
First Prev 5 of 11 Next Last
JD1964
there is enough sticking out to grab on to
3,650
1,672
194
Maryland
Oct 12, 2015
#81
  • Oct 12, 2015
  • #81
Good news! I just got a tracking number for the crank pulley. So, It should be here Thursday of this week so I might get this together sooner than I thought. Still waiting on the injectors as well.
The smog pump idler came in and I'm working on that now. With that I can get the blower and alternator permanently mounted and secure all wiring, tubing and whatnot since portions of that stuff had to be moved from their original positions. The UPR smog pump eliminator appears to be decent quality.
Reactions: a91what and TOOLOW91
JD1964
3,650
1,672
194
Maryland
Oct 13, 2015
#82
  • Oct 13, 2015
  • #82
Dammit!!! I broke the vent plug. Luckily the piece came out of the unit easily. Ordered a new one. $45 mistake. I must remember the brass vent plug is fragile.
1990Coupe
1,462
132
114
Toms River NJ
Oct 13, 2015
#83
  • Oct 13, 2015
  • #83
Subd!
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Oct 13, 2015
#84
  • Oct 13, 2015
  • #84
John Dirks Jr said:
Dammit!!! I broke the vent plug. Luckily the piece cam e out of the unit easily. Ordered a new one. $45 mistake. I must remember the brass vent plug is fragile.
You can't
damn,, you cant find a brass plug that size at NAPA or Home Depot? $45 for a plug.. ouch
JD1964
3,650
1,672
194
Maryland
Oct 13, 2015
#85
  • Oct 13, 2015
  • #85
mikestang63 said:
You can't
It's a specialized vented plug.
Vortech 7P375-058, Vortech Supercharger Accessories | Vortech
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Oct 13, 2015
#86
  • Oct 13, 2015
  • #86
saved ya $10
Vortech 7P375 058 Vented Plug V3 supercharger Self Contained | eBay
JD1964
3,650
1,672
194
Maryland
Oct 13, 2015
#87
  • Oct 13, 2015
  • #87
Thanks but I already pulled the trigger on Jegs. Should get it real fast that way, usually.
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Oct 13, 2015
#88
  • Oct 13, 2015
  • #88
Should've asked Nick @84Ttop for one, he probably has one rolling around in his ashtray
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Oct 13, 2015
#89
  • Oct 13, 2015
  • #89
Guys got all kinds of cool rolling around in that truck !
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Oct 13, 2015
#90
  • Oct 13, 2015
  • #90
TOOLOW91 said:
Guys got all kinds of cool **** rolling around in that truck !
He probably has an extra S trim laying around..;lol
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Oct 14, 2015
#91
  • Oct 14, 2015
  • #91
Yes, Yes I do...
That was our little secret
You would think so, this happens to be the most commonly misplaced part in all of these kits and I know I don't have one. We have probably ordered a half dozen this year though
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Oct 14, 2015
#92
  • Oct 14, 2015
  • #92
84Ttop said:
Yes, Yes I do...
Hey I didn't tell anyone it was the flux capacitor ... Oh wait never mind cats out of the bag now !
Reactions: 84Ttop
hoopty5.0
mechanicus terribilis
7,854
6,994
214
SW Houston
Oct 14, 2015
#93
  • Oct 14, 2015
  • #93
84Ttop said:
Yes, Yes I do...
I'm struggling to make 250 hp and this guy has to move S Trims out of the way to a clear spot on his work bench.
The distribution of HP in this country...
Reactions: a91what, 84Ttop, JD1964 and 2 others
JD1964
3,650
1,672
194
Maryland
Oct 14, 2015
#94
  • Oct 14, 2015
  • #94
It's really a good thing they make the brass vent plug so weak that it easily breaks. One would much rather break the plug in half than strip the threads in the blower housing.
JD1964
3,650
1,672
194
Maryland
Oct 14, 2015
#95
  • Oct 14, 2015
  • #95
Couple questions while I'm at it;
1) My boost will probably be in the 6-7 psi range on this entry level kit. What should my initial ignition timing be set at? Currently, I'm at 12 BTDC.
2) How do things that are normally under vacuum respond when they now are subjected to pressure? For example, the brake booster, does that have a check valve built in at the brake booster fitting? What about my Kirban FP regulator, is that designed with some type of check valve so it does not get subjected to pressure?
I'm sure the kit instructions would have mentioned these things if they were issues (they didn't) but I would still like to know for my own sake.
Still waiting on crank pulley and fuel injectors.
I put the SCT chip in. Now I'm on the way to get vacuum line for the PLX module for the boost gauge.
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Oct 14, 2015
#96
  • Oct 14, 2015
  • #96
My Kirban reg was fine ran it to 7.5psi . All the vac accsessories were fine . Set fp 42psi vac off . Set Timing at 10btdc
Reactions: JD1964
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Oct 14, 2015
#97
  • Oct 14, 2015
  • #97
Im under the impression that all chips require the timing set at 10*. Make sure you use the best octane pump gas you can find. The chip you have has already been programmed for your combo correct? What if it needs a tweak? Is this an email tune setup or a local shop/tuner?
Reactions: JD1964
JD1964
3,650
1,672
194
Maryland
Oct 14, 2015
#98
  • Oct 14, 2015
  • #98
Chip was pre-tuned by 84Ttop according to my specific setup. MAF speced and ordered by him as well along with the V3 kit. So, I should be close right off the bat. My wideband will tell me if it's being satisfied with fuel delivery or not. In the event it needs changes, tweaking the fuel pressure will be easy for me. With all that said, I should be able to get it in the sweet spot without the need for pro dyno tuning. If I'm off in my opinion, please correct me.
Reactions: A5literMan
JD1964
3,650
1,672
194
Maryland
Oct 14, 2015
#99
  • Oct 14, 2015
  • #99
What's the quickest way to kill electric power to the fuel pump? I want to turn key on and test some things but the injectors are out and I dont want to dump gas everywhere. I already tried putting the old injectors back in the rail but the pressure shot one out.
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Oct 14, 2015
#100
  • Oct 14, 2015
  • #100
Pop the inertia switch in the trunk for the pump in case of a roll over .
Reactions: JD1964, 1990Coupe and A5literMan
  • 3
  • 4
  • 5
  • 6
  • 7
  • 11
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
