V3 install
  • Thread starter Thread starter flints82
  • Start date Start date Apr 14, 2010
F
flints82
  • Apr 14, 2010
I am installing a V3-SI on my 88 GT.Also i am converting to MAF at the same time.I want to run between 8-12psi.I would like some info on what size injectors,which MAF meter I need to use.I have a C&L 73mm housing already.I am a new member and have been reading on this but I need to buy these parts and dont what to buy the wrong ones.
M
Mike in Texas
121
  • Apr 14, 2010
V3
Are you setting this up to race or more daily driving. 8-12 psi is getting into some serious boost and horsepower.
F
flints82
  • Apr 14, 2010
Both! I want to be able to drive & can drive with some driveability issues but I only want to buy these parts once. I've done an SC set-up on my 1977 F150 but it is a roots 671 with dual carbs. I had this motor built for this much boost and I want to use it to its full potential. Any advise is greatly appreciated.
M
Mike in Texas
121
  • Apr 15, 2010
V3
Fuel Injector Calculator from WitchHunter Performance will help you with the injector sizing provided you can make a fair estimate of your fwhp. I stayed with the 24#ers and FMU because I like it for daily driving. I had to change from a C&l to Pro M maf when I installed the SC to get a decent idle. One more thing, DYNO TUNE after you get it all together!
F
flints82
  • Apr 16, 2010
Ok Thanks for all your help.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Vortech V3 Si - Bypass Valve to BOV swap issues
  • seanmahoney
  • Jun 26, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 26, 2025
seanmahoney
Forced Induction Vortech bypass valve necessity
  • 92Rustang
  • Aug 28, 2024
Fox 5.0 Mustang Tech Sep 2, 2024
Cheapskate207
  • dan50
  • Jul 18, 2026
dan50
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
