v6 t5
You'll need a 85-93 input shaft and if I remember right, the sn95s have an electronic speedometer so there may or may not be a place to plug your stock speedo cable into.
Make sure you properly shim the input shaft bearing retainer. If it gives you any trouble you can make a trip up to my place if you want and I'll help you out. I rebuild them so I know quite alot about them.
