V8 clutch cable.
351wcoupe
1,811
Manhattan, Kansas
Just wondering who here is using a V8 adjustable cable. V8 quadrant and firewall adjuster?
My 351w is going automatic andI 'm looking to use up some parts, Especially since I'm having clutch problems anyway.
The V8 cable housing is shorter...but it doesn't look like it will affect anything.
Are there any problems when using this entire thing?
Quadrant and FWA are the same, I'm running the UPR right now. The diff between the 5.0 and 2.3 main cables is the attachment point at the clutch end, and maybe length as well. I'm sure you could get rid of it easily in the 5.0 section.
Ash
I have used the BBK 5.0 cable on my 90 lx. I did have to make a new yoke at the bellhousing end though. the BBK uses a threaded end at the bellhousing and the hole in the yoke was too small. When I tried to drill it larger the yoke cracked. I Flattened some exhaust tubing and made a new yoke out of that. I also had to cut some of the threaded portion off, because it was too long.
