vacuum at idle question
87Saleen#166
11
Fremont, Ca
When I fire up my car for the first time in the day, my vacuum sits at about 9" vacuum at idle. From past experience my ideal engine idle it should be at 10". With it at 9" the idle is off a little and can see my engine shake (at times), but very little. THe weird part here though is that after i let it warm up and drive the car around, the vacuum will inscrease to 10" and run nicely, but as soon as i turn it off and run it again, it seems like i have to let it run for a couple minutes for it to regain those quarter inches of vacuum. my question is, where could a vacuum leak this small come from, i've sprayed a lot of my fitting and hoses and didn't find anything.
also, is the vacuum in the crankcase suppose to equal that of my intake? or +/-?? just wondering because it's the same. and if it's not suppose to be the same what does that mean?
Metal parts expand with heat, the engine is looser when cold and tigherter when warm. It's an older higher milege motor, right? There might not be much you can do about it. but I don't know, I could be wrong.
I think mine does the opposite, cold start up its at 14 or so then after about a minute it drops down to 13. Im assuming your motor isnt stock, you should make a sig with all ur mods...Im assuming you have a blower and boost gauge since not many people have just have a vacuum gauge, allthough I do....Im only using an E303 cam...I think 9-10 is too low for vacuum unless you have some crazy cam or something. A stock motor should have about 18+inches of mercury......Make a sig with ur cam and heads and combo...I would look to see if you have any vacuum leaks first...9-10 is pretty low in my opinion
my stock motor was at about 15 with a HUGE Vac leak (blown lower intake manifold gasket). so i would think 9-10 is pretty low. i have thought about putting in a vac gauge in my car, as i am gonna put in one of those radio panel gauge pods and it has 3 gauge holes. so i'm thinking oil pressure, temp gauge and vac gauge...i was having the same problem as you though, except i had a REALLY erratic idle, and although i sprayed everywhere i could, i could NOT find a vac leak. i finally found mine by covering my TB while the engine was idling. it didn't shut off, lol. it just idled lower and i heard a whistling around the lower intake. that's when my suspiscions were confirmed. just replaced the intake gaskets the other day and MAN does that car run different. i also had lost some top end due to the vac leak. car feels much better now! good luck with yours
Josh
The lack of vacuum might have something to do with the engine under constand load from the blower, and the blower pushing a little air at the same time. Take off the S/C belt and see if that changes anything. Just a thought that I would do if trying to find your issue. Also, it is common for there to be low vacuum at lower rpm's with a cam like that. My B cam, I was pulling about 6-8".
TomCat said:
My cam has Ecam specs and I pull 16" at idle cold, 17" warm.
The E cam is a very mild cam, has no overlap, that is why it's emmisions legal even in california and is great for blowers and mild nitrous. The TFS cam on the other hand is very different.
At cold start it is normal to have lower vac by 1-2" But, when restarting the engine hot this should not be the case, as the pistons rings etc. are still at temp. The other possibility is that the drop in rpms that you are seeing is causing the low vac reading.
Maybe you have a sensor issue? Pulling codes should answer that.
Sounds like an issue with the open loop startup settings.
Is the crankcase vac there only at idle?
Actually, I am not sure how you can get crankcase vac on a boosted motor, anywhere but idle. I just wanted to make sure, because it sounds odd.
wow, I pull 14hg of vacuum w/ my B303 in the GT; that seems to be about the norm for most B303 guys I've read about on here.
Pulling the s/c belt off is worth a shot since it's easy and non-invasive. I can't think of anything else except for a vacuum leak somewhere:shrug:
What type of gauge are you using to base this off of? Is there a chance there's an error with the gauge or setup? My autometer vac gauge kept getting a bend in the little plastic line, which screwed my readings all up. The car is put up and I never fixed it.
