Hi there,
I bought a vacuum gauge and connected it to the fitting on the side of Demon Carb. The manual describes it as "direct manifold vacuum for diagnostics, accessories or distributors that use manifold vacuum for timing advance". The other is "ported or timed vacuum for spark advance to occur with throttle opening". My Electronic distrubutor is connected to the second one.
The gauge moved very fast between 23-27 in/hg. When I played with the carb idle screws the values moved up to 25-29 in/hg and down to 21-25 in/hg. But the gauge moved really fast.
What do you think about these? Valve problem, idle mixture problem? Are these correct? or any other faults with the engine and/or carb?
thanks in advance..
thanks in advance..
