  • 1994 - 1995 Specific Tech
Vacuum Issue
  • Thread starter Thread starter 94 Cob
  • Start date Start date May 14, 2011
9
94 Cob
29
NC
May 14, 2011
  • May 14, 2011
Rough idle and my vacuum gauge is only reading 5 inches at idle, but goes to 20 when I give it gas. It should be at 20 idle and head towards the 0 when I give it gas right. I'm sure I have hooked something up wrong, but I can't figure this one out.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
May 14, 2011
  • May 14, 2011
Did you recently perform any engine work, such as replacing your intake? It's entirely possible that you have everything attached properly, but your leak is at the intake somewhere.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,647
214
Acworth, GA
May 14, 2011
  • May 14, 2011
That's a major vacuum leak somewhere.
Kurt
9
94 Cob
29
NC
May 14, 2011
  • May 14, 2011
It's all new...the entire engine. I can't hear it leaking anywhere, but i will check around the intake and see what I find.
9
94 Cob
29
NC
May 18, 2011
  • May 18, 2011
OK vacuum issue solved.....it helps to have all the bolts tight on the intake...duh.
Thanks for the helping.
Another issue though. Trying to get the timing set cause it still runs like total crap. When I pull the spout the car dies and won't start. I have tried to move the distributor around to get to run w/o the spout and no luck. Is the car not running w/o the spout as sign of another issue. Bad TFI maybe??
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,647
214
Acworth, GA
May 18, 2011
  • May 18, 2011
It's a sign that the timing is way of, or the idle is set too low. Try adjusting the idle screw up temporarily to get it to idle. Just keep messing with the distributer, and you'll get it. To get a baseline, turn the engine over with a wrench. Take white out, and mark a line down the side of the distributer from the the number one lead all the way down to the cap adapter (doesn't necessarily have to be white out, a good marker will do. I just find that white out is the best marker for engine and car stuff). then pull the distributer cap, and line the distributer until the rotor is pointing directly at the white line. If the rotor is pointing in the opposite direction of the white line, the number one cylinder is on the exhaust stroke. Turn the crankshaft another 360 degrees and realign the marker with 14 degrees again. It should be pointing at or near the white line.
Kurt
toyman
1,944
54
79
Vernon BC
May 18, 2011
  • May 18, 2011
If the car won't run with the spout removed leave it in and check the timing @2500 rpm. You should be at about 34*. If it's higher or lower adjust to 34* at that rpm. Then pull the spout and I'm certain the reading will be close to 10*.
9
94 Cob
29
NC
May 19, 2011
  • May 19, 2011
Thanks for the help! I will try again this weekend and see if I can't get it right.
9
94 Cob
29
NC
May 22, 2011
  • May 22, 2011
Well I got it to where it will run w/o the spot in, but it runs so bad w/o it that it is not firing the number one cylinder consistently making it difficult to set the timing. it will run ok with the spout but as soon as I pull it out the car runs like total crap. I had a friend of mine who is a mechanic come help me today and he can't figure it out either. Very frustrating.
toyman
1,944
54
79
Vernon BC
May 22, 2011
#10
  • May 22, 2011
  • #10
Has the cam been changed? Mine with the Spout pulled doesn't idle as smoothly as it used to with the stock cam.
9
94 Cob
29
NC
May 24, 2011
#11
  • May 24, 2011
  • #11
It's a stage one trickflow cam.
I'll try to get a video up this weekend.
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
