  • 1994 - 1995 Specific Tech
vacuum leak??
  • Thread starter Thread starter btracer02
  • Start date Start date Apr 22, 2004
btracer02
146
coatesville, PA
Apr 22, 2004
  • Apr 22, 2004
the car has a slight tap comin from the mid driver side of the car. the car has recently lost bottom end power and started running richer than usual, also it now backfires after letting off the throttle.... im goin to buy new distributor cap and rotor, new fuel press reg and see if that clears it up a lil... i just did a lt/x pipe install and i was thinkin the 02 sensor may be messed up or not in tight enough.. possibly the headers werent tight enough and i have a leak in the gasket?? any suggestions?
9
95StocK50
398
Idaho
Apr 22, 2004
  • Apr 22, 2004
i think your on track with an exhaust leak, if it sounds like a ticking sound thats probably what it is
nathan
S/CBlack95GT
2,018
Tampa Palms, FL
Apr 22, 2004
  • Apr 22, 2004
I would bet on an exhaust leak as well. I had one once with my old crappy BBK headers and the car backfired when I lifted.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 23, 2004
  • Apr 23, 2004
If you are running rich, you don't have a vacuum leak. Vacuum leaks make your car run lean (unmetered air).
The ticking is from an exhaust leak. My buddies 91 GT does the same thing. He is getting copper gaskets to eliminate the problem.
Find out which one is leaking, and make sure it's tightened down to spec. If it is, the gasket might not have seated properly.
Scott
Slow5.0
2,554
Portland, OR
Apr 23, 2004
  • Apr 23, 2004
Hey I forget to tell you , mine Stang looks like run too lean on cylinder #8 , thats why is't f*** up , this weekend I will pull U/L Cobra intake and see do I have any leak
Slow5.0
2,554
Portland, OR
Apr 24, 2004
  • Apr 24, 2004
What cause engine runing too lean,
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
  • dan50
  • Jul 18, 2026
dan50
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
