It's not necessary to adjust the TPS. It is reference by the EEC at startup and scaled.
Might [might] be necessary with a new TPS is a Base Idle Reset.
Could vacuum issues be the reason my car is running pretty rich? It seems like on the forums it’s divided. Either it causes it to run rich or lean.
throttle bodies.Think so? The 20 volt DCV.Idk how you are getting that much voltage are you sure you are on the right multimeter setting?
