Vacuum Line Q
On a 5.0 efi how many vacuum lines come off of upper intake, sans anything emissions related.
Installing RPM 2 and trying to clean up engine bay as much as possible.
Any tips in that area appreciated as well, got the wiring looking pretty good and simplified. Moved crane Hi-6 box inside car, loomed a lot of stuff together ect. Re taped pretty much entire harness.
So we need one coming from front to canister, one to PVC, vac manifold, and fpr, that's all that's necessary I think. Can I use the two opposite each other near throttle body for purge and fuel press? I'm not sure vacuum is the same at that point in intake?? (Although I do believe fpr was connected there at throat of previous intake) which sadly was a pp typhoon.
No- the two lines on the TB are not vacuum- they are for the EGR coolant. Follow the diagram I posted
No, I'm not speaking of the coolant connections on egr, they are long gone. I'm talking about the threaded vac ports in neck of rpm 2 upper, just beyond the tb and egr. Should be same vac there as in plenum from what I can find. Just concerned that I might need to have them more down stream, still might be to close to throttle blade but I think physics should be same drop when blade opens there as it is past "throat" of upper.
Thanks for diagram!
