vacuum question 68 302
  • Thread starter Thread starter moonshadow
  • Start date Start date Dec 3, 2010
M
moonshadow
  • Dec 3, 2010
hi all i had a question about vacuum. I hooked up my vacuum gauge at idle and the needle pegs out at 30 hg. Is too much vacuum a bad thing.
PoppyMod
617
Severna Park, MD
Dec 3, 2010
  • Dec 3, 2010
I've never heard of manifold vac that high when checked, as noted below. Where are you connecting? I assume you know normal high side is 22".
The usual places are pure manifold accesses such as "full" vac side of carb base, PCV, or booster vac ports.
Hmmmm?
rbohm
6,698
550
204
tucson,az
Dec 3, 2010
  • Dec 3, 2010
i ma betting that your vacuum gauge is suspect. i have yet to see an engine draw more than 25-26" of vacuum at most, 18-22" is average.
D
D.Hearne
11,730
south louisiana
Dec 3, 2010
  • Dec 3, 2010
Be that as it may, 30 inches of vacuum is not a bad thing. The more it'll pull at idle, the healthier your bottom end is.
M
moonshadow
  • Dec 3, 2010
[/IMG]
M
moonshadow
  • Dec 3, 2010
this is where im connecting
PoppyMod
617
Severna Park, MD
Dec 4, 2010
  • Dec 4, 2010
I afraid your pic dd not present itself. Describe where you attached you vac gauge.
Thanks!
Max Power
1,774
St Paul
Dec 6, 2010
  • Dec 6, 2010
Thanks!
Yeah it did.
I suspect a gauge problem. That T is fine.
PoppyMod
617
Severna Park, MD
Dec 6, 2010
  • Dec 6, 2010
Max Power said:
Yeah it did.
Thanks, I see it now. When I first looked for it and you indicated it was there, I didn't see for some reason. Oh well! That certainly looks like a good location to get a reading.
Good Luck!
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
