Fox Vacuum Tee question
Vulpes5.0
5 Year Member
Nov 17, 2018
143
27
38
Warner Robins, Georgia
I'm doing away with much of the vacuum related things on my foxbody, and I want to keep many of them capped at the intake to keep clutter down with my GT40 intake.
Can i use the port on the vacuum tee labelled "B/R" (second from the left) to run my MAP sensor? It's originally capped off. I realize that vacuum is vacuum, but I wanted to make sure the MAP sensor isn't going to have trouble because of it. I would normally run a line right up to the sensor from the intake but it only has 3 ports on the back side, and they're all 3/8 line so I'd need a fitting reducer that looks very ugly.
Thank you for your time!
