Vacuum Test Low?
I'm looking at buying a 95 GT vert and I checked the vacuum pressure to see how the gaskets and everything were, but it came to 10inches at idle and it went down to zero when I gave it full throttle. When idling, the vacuum jumped up and down from 8 to 12 inches, but it has a cam. Does this cam affect the vacuum pressure?
a cam will affect the vacuum. i have not had a car with a gauge (or that i checked) that had a cam to know if the vac should jump around like that at idle.
on stock fox 5.0's, 15-20" is good. but as said, the cam will knock that down. as i recall, folks with alphabet cams run about 10-12", but i could be wrong.
when you floor the pedal, the vac will drop to almost 0 - that is normal.
good luck with the possible purchase. i hope to pick one up soon (one reason i haunt you guys in here). :)
My vacuum at idle is around 12-14" and drops to zero even at half- or maybe quarter-throttle. I have a vacuum guage mounted right on my dash because I had severe idle problems when I first put the motor together. As long as it idles I'd say you're fine. And yes, the cam will definitely effect the vacuum.
