Value of this stang....
Bullitt4711
15
Poway, CA
I am considering purchasing a 2001 Mustang Bullitt that has approx. 28K miles on it. Body condition is pretty dang good as far as I can tell. It has been driven in MA.
The mod list is as follows:
Mods:
-Catback by Magnaflow
-Mac off road h-pipe
-Mac Long tube headers
-Densecharger cold air intake
-K&N filter
-PRO-M 85 mm (clibrated for injectors)
-Ford Racing 24 lbs Injectors
-Comp Cams- Cams
-Comp Cams- Valve Springs
-Sroker kit bored 30 over making it 302
(with forgged internals) - by Powerheads
-p&p heads and intake
-Cobra R oil Pan
-3.90 gears
-Spec Stage 2 clutch
-Spec Stage 2 Flywheel
-Aluminum Driveshaft by Ford Racing (installed just last month)
-TKO-500 Transmission (installed just last month)
-Steeda 5 link 2 suspension
-Steeda Lower Control Arms
-Steeda rear springs
-Steeda Grille Delete Kit
-Steeda Ball joint adjusters (installing right now)
-Steeda bumper steer kit (installing right now)
-Steeda Front sway bar (installing right now)
-Steeda camber caster plates (installing right now)
-Steeda Tri-ax shifter
-Eibach pro kit front springs
-KB strut bar
-Iforgged(AERO BLACK)Rims 19X9 19X10.5
-Tires RE050 Bridgestone/255front/285rear
-5.0 emblems
-MRT shifter knob
-HID Kit white low/hi beams
-Ceramic Brake pads
-Drilled Slotted Rotors
-MIL Eliminators
-Superchip dyno tuned by (Dezracing)
-Saleen Front Fasica with (JMS products inc. custom carbon fiber Grille inserts)
The Bullitt is making 305rwhp & 323rwtq.
So my question... What is the Bullitt worth as it stands???? THANKS!
~Colby
crap load of mods and only 305 HP....(yes I know not many are performance, but still)
I would've saved money and supercharged it.......
and why is there 5.0 emblems on a 4.6?
I don't know how much its worth! :D
^^^Cause its stroked to a 302.
Yeah he could have done it cheaper with a s/c, but you have to give a n/a setup credit... It does need new cams to work better with the stroker engine and the p&p heads... But other than that the car is set! I think if I get it I will put a 150 shot of N20 on it... ;)
Before I bought mine I found one at a dealership for $19500 sticker, So subtract a few (maybe). But it was supercharged and only had 4k miles on it. The guy traded it in and a 04 cobra plus cash for a ford GT.
