Valve Cover baffles
Paul Perreca
1,085
I have 2 questions...
1) My valve covers are hitting my rocker arms because of the baffles in there - the valve covers are for carb engine, but my dad still wants to use them because he lost the receipt to them. CAN I CUT THE BAFFLES OUT AND MAKE THEM WORK??? EXACTLY HOW DO I MAKE THEM WORK!???!!?
2) Same as before, clearance problems, if i do order the EFI valve covers, what are the EXACT ones that i need to clear my roller rockers?? they are only 1.6, I do not want to order the correct valve covers, and still have to cut out the baffle inside... I want them to fit, is it definate, that i WILL need an intake spacer if i get TALL valve covers??
PLEASE HELP!!
Engine is SOOOO CLOSE to done, this is my last problem to deal with until we start installing it!! THANKS!!
Perreca
I can't say what combinations will and will not work. There are far too many possibilities for me to care about.
You do have to have that baffle in place though. You can cut it out and weld/bond/bolt in another one that will clear. I actually used JB Weld to bond in a very thin sheet of Al. Bottom line is that no Baffle = Major Oil in Intake.
jason
Just throw a breather on the one hole, that's not a problem......I always thought the fuel injected valve covers were shorter than the carbed ones though??? I don't see the harm in taking the dremel to the baffle though. We had to unscrew the baffle on the stock valve covers when adding 1.7 rockers to my friends 89.
Paul I run the "Powered by ford" EFI covers...they also had baffle clearance problems. Provided the inside of the Valve covers are the same there should be a cover plate over the oil spout...that cover needs to be removed by what ever means necessary, and the studs under the plate ground down via hand grinder. Now the clearance should be sufficient to work with the RR's so clean out ALL the shavings and your good to go. As for cleaance issues you should run the 1" spacer to accomodate the TB and linkage...those VC should work. Valve covers that WILL work first time..here's a link should you choose to go that route...Good luck Paul modding a ford is always the same..nothing ever works like it should, nothings ever easy, it always cost more than ever imagined, and in the end it's all worth while.
http://www.blueovalindustries.com/products.php?pid=565&openparent=9902081&dealer=blueoval
and your 100% sure those valve covers WILL work, and I don't have to put on an intake spacer, or cut out any baffles? def gotta be chrome too lol - thanks for your help guys!
They will work without the spacer...should the baffles have to come out it is REALLY quite simple with a grinder and carbide bur..but you will not need to remove the baffles in my honest opinion. If your worried call John at blue oval and talk to him...great guy he'll take the time to give you the info you need.
Actually Paul I used the FMS EFI covers from Summit..they are the polished ribbed covers with the powered by ford Mustang on them. If I could do over again I would have gone with the blue oval chrome set..nicer finish and easier to maintain. Call John at Blue oval he did have a pic with a ruler on the backside of the cover showing exactly the amount of clearance. With that info you can measure the ones you have now and determine the clearance you need. But Paul even if you do have to knock out the baffle those covers would compliment the engine VERY nicely..and fit with the intake/tb without the issues of the tall covers. The motor looks good...with the chrome EFI covers it will look even better IMO. If you need a number for Blue oval just let me know. 1-866-686-BLUE.
if i call that number, he will give me a price, and i'll send him a check or MO for that amount, and he'll ship them, or is he just gonna tell me what ones to get?? What about the ones in the link that you sent me?? Can I use them?? I like them alot lol thanks
The ones in the link are the ones I'm talking about...they are correct for EFI mustangs and will work with roller rocker..like I said call john tell him what rockers your running and he can easily confirm fitment. Those rockers should not sit any higher than my scorpions...but like I said I removed my baffles in 10minutes as the VC's I chose from summit did not clear untill the baffles were removed. When modding a 5.0 there's always some "work" that needs to be done to get it right. Just consider it your way of customizing it ;), we all have to do it for one thing or another....if you had too you'd have no problems doing so.
18mustangs said:
:bs: That's exactly what you should NOT do unless you want a big vacuum leak via the PCV system. It's called a CLOSED crankcase for a reason.
Really? Cause I've seen a few 5.0s set up like that and I don't imagine they had problems if they were doing it. Then again, maybe they had problems and didn't realize that's why :P Good to know though.
Several different versions will work on his setup, but he's looking to make the bay look as well as it's going to run. In my opinion the more "shiney stuff" the better..but everyone differs on that, and no one person is right. In his case though the chrome covers will work excellent with the rest of the components and create a very nice looking engine.
