- Mar 30, 2005
- 1,085
- 0
- 0
I have 2 questions...
1) My valve covers are hitting my rocker arms because of the baffles in there - the valve covers are for carb engine, but my dad still wants to use them because he lost the receipt to them. CAN I CUT THE BAFFLES OUT AND MAKE THEM WORK??? EXACTLY HOW DO I MAKE THEM WORK!???!!?
2) Same as before, clearance problems, if i do order the EFI valve covers, what are the EXACT ones that i need to clear my roller rockers?? they are only 1.6, I do not want to order the correct valve covers, and still have to cut out the baffle inside... I want them to fit, is it definate, that i WILL need an intake spacer if i get TALL valve covers??
PLEASE HELP!!
Engine is SOOOO CLOSE to done, this is my last problem to deal with until we start installing it!! THANKS!!
Perreca
PLEASE HELP!!
Perreca
That's exactly what you should NOT do unless you want a big vacuum leak via the PCV system. It's called a CLOSED crankcase for a reason.
, we all have to do it for one thing or another....if you had too you'd have no problems doing so.
Good to know though.
