Howdy All,
I have a 333 Cubic Inch stroker setup 9.5 to 1 compression ratio ultradyne custom cam, vic jr intake, aed 'eliminator' carb and a small nitrous system (125/250 wet shot).
I currently have a K&N breather on either side of the motor (on the valve covers) and all seems well except oil is leaking out of the breathers because the valve covers are no baffled. I believe if I exchange the covers for baffled ones, I wont have this issue. Am I correct in thinking this?
Second off -- I have access to a Mr. Gasket Crankcase Evacuation system, which puts breathers in the valve covers, with hoses that go to a check valve and the check valve screws into a tube that gets welded at a 45 degee angle into the collector of the header.
I think I'm going to just first swap valve covers and see if that fixes my issue. If it doesnt, then I'm going to go install the crankcase evacuation kit.
Does anyone have experience with what I am speaking of?
Car had a mr gasket evacuation kit on it previously but that is because it was a drag only car. Now its for the street. Should I be groovy if I put baffled valve covers on and just swap the breathers to those covers? Or am I going to cause bigger issues, etc.
Let me know!
-Gered
Let me know!
-Gered
