valve covers, roller rockers, oiling?
allcarfan
The Answer Man
2,458
North Atlanta
I purchased a set of valve covers. The covers had the baffles removed so they would clear a roller-rocker setup. I am concerned that oil may find its way out of the oil-fill or breather hole. What can I do to alleviate this problem, aside from brazing in a 'screen' over under the hole?
You can set up a scavenger/catch can system that hooks into the breather holes. These are common on road-race cars.
Other option is to braze on high breathers similar to these:
allcarfan said:
Dont want to give up my aluminum ribbed cobra valve covers. :(
Understood. I had the same valve covers on my first Mustang. I ended up keeping the internal baffles and purchased 1" spacers from Ford Power Parts. Unfortunately, they no longer carry them.
I did a google and found this:
http://www.flatlanderracing.com/vcbbstuff.html
This will allow you to keep your existing valve covers and re-install the internal baffles.
