Valve guides too tight.
  • Thread starter Thread starter Shakin66
  • Start date Start date Nov 26, 2006
Shakin66
628
Waycross, Ga / Lake James, NC
Nov 26, 2006
  • Nov 26, 2006
Well about 3 months ago I bent a valve and was here asking about Piston to valve clearance specs and you guys helped me out a lot. I reassembled the head with just the weaker inner springs and then stacked up .100" of feeler gauges under the rocker tip and turned the engine over...Everthing was fine and with this method I was about to determine that I had closer to .125" before contact. Fast forward to today, after reassembling the heads with new springs I drove the car until it got up to 180 and WACK it did it again. After disassemble I noticed that on the valves there was some metal transfer and took it and the head to the machine shop where I was told..."We have your guides too tight". Morral of the story I guess is to check everything that comes out of your local machine shops. I would have been driving my car for the past 3 months if not to thier mistake.
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
Progress Thread 1989 LX 5.0 convertible - mild project
  • Scott_S
  • Aug 18, 2025
  • 5 6 7
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2026
DadLife0724
Fox 89’ GT 331 stroker, Trickflow upper/lower, TF#3 Cam, stuffed with forged goodies.
  • 08GT500
  • Nov 6, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 6, 2025
08GT500
