Im currently arguing with a machine shop over recent work done on my heads. The performed a 3 angle valve job, and I went to mount new roller rockers and found alot of clearence/ lash between tip of roller and top of stem, and its different on all cylinders. But then theres none with the stock rockers back on instead. So I figure longer pushrods right???? Anyway my problem is that all rockers are different lash, some are at 0 and some at .066". What is the MAXIMUM amount of tolerance on installed valve height differences between valves???? I would assume being there is no adjustment in rocker that there needs to be no difference and they all need to be the same?? I think the fix for my problem is have all valves be at the same installed height, 1 set of 16 longer pushrods and a shim kit for the rockers.......Any advice or anyone been here before? The machine shop says they did everything perfect and its setup like factory, I think this is bull**** b/c if so this would mean I need 16 different length pushrods. WTF
