asecretfile New Member Feb 11, 2007 228 0 0 Aug 14, 2007 #1 Aug 14, 2007 #1 on a cam with an advertised lift of .542 int. and exh. if using 1.6 rockers instead of 1.7 how much does the lift change? Thanks :SNSign:
5spd GT "the 5.0 owns all" Founding Member Aug 7, 2002 9,516 6 99 Arkansas Aug 14, 2007 #2 Aug 14, 2007 #2 .542" lift divided by (current roller rocker) 1.7 = .319" Lift at the Lobe. .319 Lift at the lobe multiplied times new desired roller rocker (1.6) = .510" lift. Duration will also take a small hit... Lift doesn't determine much. At peak lift the piston is near 2.00" down in the bore... Check for p-v clearance... Good Luck!
