When I start my car, there is a very loud noise that sounds like a valve lifter. FWIW, is seems to be coming from the passenger side. The noise is worse when the engine has some load on it. Then after a few minutes, the noise goes away completely and the engine runs without any noise until the next time I start it up.
I found this here:
http://www.buicks.net/shop/reference/noisy_valve_lifters.html
I am getting an oil change soon and I am going to use a good synthetic oil. But for the moment, is there anything I can put in my oil to clean out varnish in my lifters?
I found this here:
internet article said:Rapping noise only when the engine is started. When engine is stopped, any lifter on a camshaft lobe is under pressure of the valve spring; therefore, leak down or escape of oil from the lower chamber can occur. When the engine is started a few seconds may be required to fill the lifter, particularly in cold weather. If noise occurs only occasionally, it may be considered normal requiring no correction. If noise occurs daily, however, check for (a) oil too heavy for prevailing temperatures, (b) excessive varnish in lifter.
