  • 1994 - 1995 Specific Tech
vapor lock?
  • Thread starter Thread starter 94pony
  • Start date Start date Apr 8, 2005
94pony
151
Arlington, Tx
Apr 8, 2005
  • Apr 8, 2005
After I drive her for two or three hours she dies like she is running out of gas. Then I wait twenty minutes or so and she will start right back up. From what I know you cant get vapor lock on fuel injection engines. I am running true dumps. I was wondering if you think my fuel lines could be getting to hot because of this? Thanks
J
Jack's95gt
443
Huntingdon Valley, PA
Apr 8, 2005
  • Apr 8, 2005
I haven't heard of a vapor lock problem in a long time. It use to knock many of road race cars out of the race. It could be as you suspected, with your exhaust from the dumps heating up the fuels lines. The fuel filter heating and the tank itself may be heating up the fuel.
K
kj2833
75
central illinois
Apr 8, 2005
  • Apr 8, 2005
It could be a number of things, could also be hall effect sensor in distributor as well, they act up when they get hot. without some tests it would be hard to guess.
Ive seen tons of dumps installed with no problems, as long as they are installed correctly i would question whether it was them causing a problem. unless its actually touching the fuel line.
94pony
151
Arlington, Tx
Apr 8, 2005
  • Apr 8, 2005
Anyone have an idea of what to check first?
K
kj2833
75
central illinois
Apr 8, 2005
  • Apr 8, 2005
Id check the fuel system over and give the ignition some scrutiny, if you are unsure about how this works get your money ready. There isnt anything you can do if you dont know how to test things.
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
