Vent tube?
Djstorm100
109
The vaccum hose that is on the oil cap where should this go? If you have a vortech sc? I looked on there and it said to put it on the intake box cover that vortec gives you. Theres a check valve that only allows air to come out the tube and not back in to the tube (and in to the motor) I'm kinda thinking that this is where I'm getting a vaccum leak from. Since I only pull 3-4 on vaccum side. Needless to say yesterday comeing home the guage when tto 21 vaccum. I turned the car off and then back on and it wouldnt read back to 21 one again. I re did all the lines (didnt replace them) but make them shorter and the shortest possible path. Also theres a vaccum line that goes from the intake manifold and down in between the heads and the smog pump/ alternator, what is the purpose of the line and can I just take it off and cap the nipple on the intake manifold?
Normally, it connects from the oil fill neck to the throttle body.
The other vaccum line you are talking about goes to the charcoal canister and helps draw gas vapors through the activated charcoal and into the engine for combustion. You should not remove this line
