Venting your rear end
  • Thread starter Thread starter mustangdave
  • Start date Start date Jul 9, 2005
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jul 9, 2005
  • Jul 9, 2005
No, not flatulence, The rear end vent hose on my 67 runs through a grommet into the trunk. This just seems stupid to put that smell in the trunk. Where does everybody elses run? What was Ford thinking?
2nd Mustang
2,488
Southern California
Jul 9, 2005
  • Jul 9, 2005
Balances out the smell from the holes in the firewall and shifter boot in my 67. But seriously, the PO installed a firewall behind the back seat due to the battery in the trunk. I still love old school stuff.
iskwezm
4,159
20
79
Rowland Heights,California
Jul 9, 2005
  • Jul 9, 2005
I dont think it was to vent fumes in the trunk,it was to keep water out.Theres very little pressure at that hose.
1969mach1351
285
Sacramento, CA
Jul 9, 2005
  • Jul 9, 2005
On my 69 it just goes up a little bit, not into the trunk.
thehueypilot
1,084
Medina,Tennessee
Jul 9, 2005
  • Jul 9, 2005
Summit sells a aluminum hex vent that screws in and is filtered (SUM-E730300) maybe you could try it and let us know if it works?
M
mustangdave
2,976
North Carolina
Jul 10, 2005
  • Jul 10, 2005
A filter is a good idea. I might try a small filter from some other application or just strap it up under the car. Every one I've seen is rotted or broken off under there anyway.
ashford
485
fargo ND
Jul 11, 2005
  • Jul 11, 2005
you can get breathers of various sizes and types at most truck parts houses
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
Jul 12, 2005
  • Jul 12, 2005
High Water maybe?
But it should go into the subframe rail to keep it higher than the diff.
not into the trunk.
PB
Edbert
3,548
32
109
Austin TX
Jul 12, 2005
  • Jul 12, 2005
The vent was routed into an enclosed area to prevent debris from getting into it. It would work just fine pointing straight up, but then your oil would be contaminated. I like the metal vent-cap with filter.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 4:43 AM
manicmechanic007
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
