  • 1994 - 1995 Specific Tech
Vert cylinder for top replaced
  • Thread starter Thread starter Pops Fun
  • Start date Start date Jun 9, 2010
Pops Fun
961
14
59
Cincinnati, Ohio
Jun 9, 2010
  • Jun 9, 2010
Hi
Last week my top wouldn't go down and I could smell hydraulic fluid/brake fluid. The cylinder on the drivers side blew!! Thought this might help someone when they have this problem....
Ordered another and my son replaced it tonight, Ordered on E-bay, Hydro-E-Electric. They have a bunch of vert stuff for older cars Tops. pumps window weather stripping etc.
Cylinder
Pump
Pump location and cylinder under speakers
Twista
510
@ the z00 in chicago
Jun 20, 2010
  • Jun 20, 2010
Funny, im doing the exact same thing. I haven't got that far yet, because i gave up because of the styling bar. Turns out i have to remove both side panels so i can remove the styling bar.
Mine is leaking on the driver side also. Not sure what yet.. might be a hose.. or a cylinder
aar0s
1,015
55
69
Jun 20, 2010
  • Jun 20, 2010
the pass side cylinder on my 88 was leaking to the point where every spring i would have to refill and prime the pump. didnt want to spend the money on a new ram so i pulled the pins that hold the top frame to the rams and work the top manually. not all that hard, top and frame is light, just kind of a PITA.
I am going to replace the motor, both rams and lines one of these days, ill have to check that place on eBay your talking about.
RMODEL65
313
brunswick ga
Jun 25, 2010
  • Jun 25, 2010
iirc the pump uses type f tranny fluid not hydraulic oil....
toyman
1,944
54
79
Vernon BC
Jun 25, 2010
  • Jun 25, 2010
Ford service manual calls for MERCON® Multi-Purpose Automatic Transmission Fluid XT-2-QDX or equivalent meeting Ford specification. Is type F an equivalent? IDK
RMODEL65
313
brunswick ga
Jun 26, 2010
  • Jun 26, 2010
type F is an older tranny fluid its not the same as Mercon....the friction modifiers are different between the 2. normally type f is a little more expensive than mercon
Pops Fun
961
14
59
Cincinnati, Ohio
Jun 26, 2010
  • Jun 26, 2010
I used brake fluid..
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
6K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Convertible Top Replacement SN95/NewEdge
  • MineralMan
  • Feb 15, 2023
7K
1996 - 2004 SN95 Mustang -General/Talk- Jul 1, 2024
old fella 2
O
Help price this Fox
  • Blueinfan
  • Jul 27, 2023
  • What is it Worth?!?!?
What is it Worth?!?!? Jul 27, 2023
Blueinfan
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
